Available NetBrain Integrations - Update (04/2021)
    Last Update: 04-2021
    What happens if I don’t see my Vendor listed below?  What do I need to do?
    Don’t worry! Our Professional Services team can help you develop an integration with your REST API, Python SDK, and SOAP API compatible 3rd party platform to further enrich your NetBrain infrastructure.
    Please contact your NetBrain Account Executive, Customer Success Manager, or open a support case with our NetBrain Technical Support so that we can get started with discussing your integration options.
    Self-Service Integrations
    What is a Self-Service Integration?
    NetBrain classifies any integration as “Self-Service” if the integration of NetBrain with the application requires no additional customization beyond the localized configuration within the NetBrain platform.  These integrations are typically Single Pane of Glass (SPoG) integrations with a templated Data View Template (DVT) where NetBrain retrieves data from the 3rd party system to enhance the NetBrain Map.  Configuration typically takes place within the NetBrain System Management and/or Domain Management interfaces and may require an additional code module to be installed locally in the NetBrain Web Server or Front Server virtual machines.
    How can I deploy one of these Integrations?
    These integrations may be deployed in one of the following ways:
    Self-Service Execution
    Self-led execution using the available NetBrain integration documentation found within the Customer Success Center Knowledge Base and our NetBrain GitHub Repository.  If you experience problems or issues, you may contact NetBrain Technical Support for assistance.
    Paid Professional Services
    If you would like our NetBrain Professional Services team to complete the integration, we would be more than happy to explain our Professional Services offerings with you.  These integrations can be completed as part of our standard services packages or a customized package.  Please contact your NetBrain Account Executive, Customer Success Manager, or NetBrain Technical Support for more information.
    Vendor
    Application
    Category
    Name
    Deliverable
    ServiceNow
    Note: Support both OAuth and Basic Auth
    ServiceNow ITSM
    Triggered Diagnosis
    ServiceNow App v2.0
    ServiceNow Application
    ServiceNow ITSM
    SPoG
    Active Incidents & Change Requests
    NetBrain DVT
    Splunk
    Splunk Enterprise
    Triggered Diagnosis
    Splunk App v1.0
    Splunk Add-On
    Splunk Enterprise
    SPoG
    Device Syslog Search
    NetBrain DVT
    Splunk Enterprise
    SPoG
    NetBrain One-IP Table History
    NetBrain DVT
    Splunk Enterprise
    SPoG
    NetBrain Topology History
    NetBrain DVT
    Splunk Enterprise
    SPoG
    Monitoring Azure Logs
    NetBrain DVT
    PRTG
    PRTG Network Monitor
    SPoG
    Monitor Sensor Data
    NetBrain DVT
    SolarWinds
    Network Management
    SPoG
    Device, Interface, and Syslog Monitoring Data
    NetBrain DVT
    Cisco
    SNTC
    SPoG
    Device Support Info
    NetBrain DVT/Qapp
    Datadog
    Datadog
    SPoG
    AWS EC2 Infrastructure Monitor (Agent)
    NetBrain DVT
    Datadog
    SPoG
    Monitoring Azure Metrics
    NetBrain DVT
    Datadog
    SPoG
    AWS VPC Security Group Threat Detection
    NetBrain Gapp
    Datadog
    SPoG
    Azure Network Security Group Logs Gapp
    NetBrain Gapp
    BMC
    BMC Remedy
    SPoG
    View Incident List
    NetBrain DVT
    NetBrain Integrations Requiring Services Engagement
    What is the difference between these integrations and your “Self-Service Integrations”?
    Integrations in this next list are highly customized each time they are deployed and are as unique as your network.  These integrations typically require customized Python scripting, deployment and customization of NetBrain software on the server-side, or additional customizations due to a database table variance in the 3rd Party Vendor deployment in your environment.
    I’d like to integrate my NetBrain system to perform one of these functions.  How can I deploy one of these Integrations?
    Unfortunately, NetBrain does not offer self-service documentation for this class of integration.  Due to the level of complexity (server-side scripting, database updates, NetBrain object coding, etc.) of each of these integrations, these must be completed as part of a NetBrain Professional Services engagement.
    Please contact your NetBrain Account Executive, Customer Success Manager, or open a support case with NetBrain Technical Support so that we can discuss your services options.
    Vendor
    Application
    Category
    Name
    Deliverable
    ServiceNow
    ServiceNow ITSM
    Change Orchestration
    NetBrain & ServiceNow Change Management Orchestration
    Gapp/Qapp, ServiceNow code
    ServiceNow CMDB
    CMDB Synchronization
    NetBrain & ServiceNow CMDB Synchronization
    ServiceNow code
    ServiceNow ITSM
    Other
    Callback framework to update triggered Qapp result back to the trigger source incident
    NetBrain Qapp
    ServiceNow ITSM
    Other
    Trigger incident ticket creation
    NetBrain Qapp
    LogicMonitor
    LogicMonitor
    SPoG
    Monitor Metrics History
    NetBrain DVT
    Splunk
    Splunk Enterprise
    Other
    Get NetBrain Data by Splunk Custom Commands
    Splunk Add-On
    Splunk Enterprise
    Other
    Push events into Splunk
    NetBrain Qapp
    SolarWinds
    SolarWinds
    Triggered Diagnosis
    Triggered Automation
    SolarWinds code
    BMC Remedy
    BMC Remedy
    Triggered Diagnosis
    BMC Remedy code
    PRTG
    PRTG
    Triggered Diagnosis
    PRTG code
    AKIPS
    AKIPS
    SPoG
    Import Device Syslog
    NetBrain DVT
    Infoblox
    Infoblox
    SPoG
    Import Trust Level
    NetBrain DVT
    Cherwell
    Cherwell
    Other
    NetBrain Qapp
    Integrated Edition 8.0Integrated Edition 8.01Integrated Edition 8.02Integrated Edition 8.03Integrated Edition 10.0
    « Previous ArticleNext Article »
     5.0 (5)
    Comments
    No records to display
    About the Author
    Subscription
    Follow Knowledge Base posts
    Please enter your email address to subscribe:
    Email:
    Subscribe
    Tags
